powerziggy
Hi! I have just purchased a used Hasselblad H3D II 31. I have also purchased a L plate to use the camera with my Gitzo tripod. I have also planned to use the camera in a commercial studio setting, with a Manfrotto geared head operation (quick release plate), and the problem arises when I want to shift the camera from the horizontal to the vertical position. I don't know how to set up the vertical position. Where should I screw on the quick release plate? If I put on the release plate, how do I make sure if will not block the PC-connector for the sync cable? Any help will be very much appreciated.
