Upgrading from 4504 flash
Photog500
I am using a 503CXi with a 4504 Pro Flash. My system is working fine but I am bracing for an eventual failure. Does anyone have experience using TTL with other flash units?
Thank you
With proflash and other "metz 300" it allways works fine in TTL mode.
Except with digital back as the IR filter and sensor reflect not like a film.
Modifcation of a 203FE for digital improve nothing.
All Metz torches from the 300 and the 3000 series work fine in TTL mode with Hasselblad 500 cameras.
Please note for other flash units than Hasselblad dedicated ones you will need the SCA 390 adapter.
These adapters are no longer available.
Last RRP of the SCA 390 was around 200 euro!
