Hasselblad filters
I think any kind of filtration and a hood are vitally important to protect the camera and especially the $3000+ dollar lens mounted to the camera.
So many people online test equipment, expensive Hasselblad equipment shooting without the hood attached. The hoods are not for show. The hood on any camera is vitally important to help reduce flare and increase image contrast especially on a sunny day. When a hood is mounted you can shoot closer to the sun without getting flare.
The UV filter is the first accessory I buy for any lens from any camera system. Especially a Hasselblad lens considering the cost, spending one to $3000 for a filter is great insurance. Does a UV filter improve image quality? Don’t know but it definitely will not hurt image quality especially if you buy a high-quality filter, Hasselblad, Hoya, B+W. My go to has always been the B+ W
I am a belt and suspender guy. All, HB and M body, have a UV + hood attached. When that lens is damaged it is too late to be thinking about protection. We always practice safe shooting. ;o)
A few weeks ago I had my X2d and 25 mm over my right shoulder. Somehow I tripped on a curb and went down, the camera slung from my right to left and hit the ground next to me. Thankfully I did not fall on the camera.
I bent my Len shade, was able to get it off but its mounting point was badly damaged and could not be saved. Purchased a third-party pedal hood as a capable temporary replacement.
I also have a Falcam cage mounted on my x2D and took a ding out of two corners on the cage. Without those two protective pieces of equipment, I am sure I would’ve damaged the lens and the camera body. Everything is fine now thankfully
Just adding to my recent reply.
I have attached 2 images demonstrating the importance of using the lens hood and (although not discussed) a cage for the x2d system. The "x2d cage" image clearly shows the two dings caused by the camera body hitting the pavement. The "xcd 28 lens hood" image shows the damaged bayonet mounting flange, which is severely bent from its normal position. after some effort I WAS able to unlock the hood from the 28.
Looking at the locations of the damage, IF I did not have a cage mounted, the body would have taken the full force of the fall. Worse, if I did not have the hood attached, all of the damage show would have been inflicted on the lens. I don't know if the screw on UV filter would have even been removable after the hit.
My big worry was how hard the hit might have damaged the working components of the camera body, but more important the components of the focus mechanism and lens shutter. The fall was now about 3 weeks ago. I've tested the camera, and 28 and everything seems to be functioning normally. Don't know if the fall might have any long term reliability effects.
The cameras are expensive. Protection is cheap: UV fiters, hoods and cages. Too late after the camera has been dropped. Why take the chance??
